Diagnostisch rapport vol met fouten?
Ik heb gisteren even Op-Com aangesloten op m'n auto en het werkt allemaal prima. Ik heb echter een diagnostisch rapport laten maken door Op-Com en dit kwam er uit:
DIAGNOSTIC REPORT:
OP-COM 100219a
hkj
**********************ECU ID STARTS**********************
Source Address: CIM
Source Address: 0x00000245
Identifier: 0x010A
VIN: W0L0AHL0855229340
System name: VALEO A3300 CIM
Hardware number:13198908
Part Number:13198908
Software version number: M:70.49 S:01.00A
System description: VALEO0400
Hardware key number: 94GDMQ
Programming Date: FFFFFFFF
Alpha code: ÿÿÿ
Manufacturing date: 20050607
Code Index and version: ÿÿÿ ÿÿ
Number of stored fault codes: 9
B3055 - Transponder Key Problem
(00) - Not present
B3925 - Wrong Environment Identifier Received IPC (Instrument)
(00) - Not present
B3929 - Wrong Environment Identifier Received REC (Rear Electrical Centre)
(00) - Not present
B3977 - Wrong Environment Identifier Received UEC (Underhood Electrical Centre)
(00) - Not present
U2113 - CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag)
(00) - Not present
U2116 - CAN-Bus No Communication with IPC (Instrument)
(00) - Not present
U2117 - CAN-Bus No Communication with DIS (Display)
(00) - Not present
U2140 - CAN-Bus No Communication with UEC (Underhood Electrical Centre)
(00) - Not present
U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
(00) - Not present
**********************ECU ID ENDS**********************
Source Address: ECM
Source Address: 0x000007E0
Identifier: 0x072A
System name: Z19DTJ
Hardware number:81012122
Part Number:55198054
Software version number: VTSMS060_S
Hardware manufacturer number: 0281012122
System description: 1037371870P319_O83
System description: BOSCH0100
Type approval number: B05029
Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
System description: 0x00015018
Alpha code: AL
Software version: O83JTD74
ECU variant coding: 0x000010C5
Number of stored fault codes: 3
P0070 -
(71) - Not present
P0650 -
(70) - Not present
P1614 -
(50) - Not present
Source Address: ABS/TC/ESP
Source Address: 0x00000243
Identifier: 0x0494
System name: ESP MK60
Hardware number:16039000
Part Number:13213610
Software version number: D4_REL00354
System description: TEVES0300
Programming Date: 00000000
Alpha code:
Manufacturing date: 00000000
ECU variant coding: 0x0000E681
No fault codes stored.
Source Address: EHPS
Source Address: 0x00000244
Identifier: 0x0203
System name: EHPS EP2 ZFLS
Part Number:13192897
Software version number: 7625379109 P522
System description: ZFLS 0011
Programming Date: 20202020
Alpha code: JV
Code Index and version: 001 01
Source Address: IPC
Source Address: 0x00000255
Identifier: 0x1001
System name: BCM/KOMBI-A3300
Part Number:13216684
Software version number: 4.405 11/04
System description: SIEM 0400
Hardware key number: 0000000000
Alpha code: PF
Code Index and version: 001 05
P0500 - Wheel Speed Sensor Circuit Range/Performance
(71) - Not present
P0654 - Engine Speed Signal Range/Performance
(71) - Not present
P0550 - Mileage Circuit Range/Performance
(71) - Not present
P0460 - Fuel Level Sensor Circuit Range/Performance
(71) - Not present
U2113 - CAN-Bus No Communication with SDM (Airbag)
(00) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
Source Address: AIRBAG SDM
Source Address: 0x00000257
Identifier: 0x0204
VIN: W0L0AHL0875037787
System name: MRSZ-Temic
Part Number:13188854
Software version number: A3300RG3 V 3.1.0
Alpha code: GS
Manufacturing date: 20060913
(00) - Not present
(00) - Not present
(00) - Not present
Source Address: UEC
Source Address: 0x00000250
Identifier: 0x0106
System name: FZM INTEDIS
Part Number:13206754
Software version number: FZM 8.16
Alpha code: HB
Manufacturing date: 20050603
Number of stored fault codes: 5
B1375 - Switched System Voltage (Ignition ON) Not Plausible with CAN Signal
(5A) - Not present
B2699 - Right Low Beam Circuit Open
(05) - Not present
(00) - Not present
(00) - Not present
U2141 - ????
(00) - Not present
Source Address: REC
Source Address: 0x00000251
Identifier: 0x0108
System name: RZM INTEDIS
Part Number:13206762
Software version number: RZM 8.12/
Alpha code: HK
Manufacturing date: 20050601
(5A) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
Source Address: ECC
Source Address: 0x00000248
Identifier: 0x0201
System name: ECC A3300
Hardware number:24452694
Part Number:13122963
Software version number: 0AL00/29C68
System description: PREH 0000
Alpha code: 000
Manufacturing date: 20050525
Code Index and version: 003 02
Source Address: EHU
Source Address: 0x00000241
Identifier: 0x0401
System name: CD 70 Navi
Hardware number:13187941
Part Number:13188465
Software version number: C0088/R4904/N0091
Alpha code: LG
Manufacturing date: 20050524
Code Index and version: 002 03
Audio Index and version: 023 04
Source Address: DIS
Source Address: 0x00000246
Identifier: 0x1201
System name: CID/GID Delta
Hardware number:13111163
Part Number:13111163
Software version number: GD59-/00050
Alpha code: KP
Code Index and version: 007 01
(00) - Not present
(00) - Not present
(00) - Not present
Wat is er allemaal mis mee? Ik snap er allemaal niets van. :thumbup
In het eerste bericht stond niet het gehele log, my bad. Ik heb toevallig gisteren alles verwijderd, moet eens kijken of ik vanavond een nieuwe log kan maken. :)
