Vandaag maar even mijn auto uitgelezen met OpCom. Ik schrok even van alle foutmeldingen in het systeem. De EGR heb ik losgekoppelt dus die kan ik nog wel plaatsen, maar alle andere?? Iemand die weet wat enkele van deze codes betekenen?
Source Address: CIM
B3794 - Switch Cruise Control Circuit Malfunction
(08) - Not present
Source Address: ECM
P0405 - Exhaust Gas Recirculation Sensor "A" Circuit Low
(00) - Present
P0500 - Vehicle Speed Sensor Malfunction
(00) - Present
P1390 - Left Front Wheel Speed Sensor Incorrect Signal
(00) - Present
P1395 - Right Front Wheel Speed Sensor Incorrect Signal
(00) - Present
Source Address: EHPS
U2105 - CAN-Bus ECM Message Range/Performance
(71) - Intermittent
Source Address: IPC
P0500 - Vehicle Speed Signal Range/Performance
(71) - Present
U2139 - Invalid Signal from CIM (Steering Column Module)
(71) - Present
B0550 - Mileage Circuit Range/Performance
(71) - Present
Source Address: AIRBAG SDM
U2139 - Invalid Data from CIM (Steering Column Module)
(7F) - Present
Source Address: CIM
(08) - Not present
Source Address: ECM
(00) - Present
(00) - Present
(00) - Present
(00) - Present
(71) - Intermittent
Source Address: IPC
(71) - Present
(71) - Present
(71) - Present
(7F) - Present
