EGR klep
Mijn auo, een Opel Meriva uit 2006, heeft inhoud en stotter problemen. Nu wilde ik de klep schoonmaken. Maar waar zit deze.
U kunt zelf kiezen.
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) C-29
P0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) C-31
P0100 Mass or volume air flow circuit high input C-10
P0100 Mass or volume air flow circuit low input C-10
P0110 Intake Air Temperature Circuit High Input C-12
P0110 Intake Air Temperature Circuit Low Input C-12
P0115 Engine Coolant Temperature Circuit High Input C-11
P0115 Engine Coolant Temperature Circuit Low Input C-11
P0115 Engine coolant temperature circuit malfunction C-11
P0120 Throttle Position Sensor (TPS) Circuit 1 Voltage High C-09
P0120 Throttle Position Sensor (TPS) Circuit 1 Voltage Low C-09
P0120 Throttle Position Sensor 1-2 Correlation C-09
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-30
P0130 O2 Sensor 1 Circuit Voltage Low C-30
P0130 O2 Sensor 1 Open Circuit C-30
P0130 O2 Sensor 1 Incorrect Signal C-30
P0134 O2 Sensor Circuit Open (Bank 1 Sensor 1) C-30
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-29
P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) C-29
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) C-29
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-32
P0136 O2 Sensor 2 Circuit Voltage Low C-32
P0136 O2 Sensor 2 Open Circuit C-32
P0139 O2 Sensor 1 Incorrect Signal C-30
P0140 O2 Sensor 2 Incorrect Signal C-32
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) C-31
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) C-31
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) C-31
P0170 Rich Exhaust C-30
P0170 Lean Exhaust C-30
P0201 Cylinder 1 injector circuit high C-23
P0201 Cylinder 1 injector circuit low C-23
P0201 Cylinder 1 Injector Circuit Open C-23
P0202 Cylinder 2 injector circuit high C-24
P0202 Cylinder 2 injector circuit low C-24
P0202 Cylinder 2 Injector Circuit Open C-24
P0203 Cylinder 3 injector circuit high C-25
P0203 Cylinder 3 injector circuit low C-25
P0203 Cylinder 3 Injector Circuit Open C-25
P0204 Cylinder 4 injector circuit high C-26
P0204 Cylinder 4 injector circuit low C-26
P0204 Cylinder 4 Injector Circuit Open C-26
P0219 Engine overspeed condition C-43
P0220 Throttle Position Sensor (TPS) Circuit 2 Voltage High C-09
P0220 Throttle Position Sensor (TPS) Circuit 2 Voltage Low C-09
P0220 Throttle Position Sensor 1-2 Correlation C-09
P0230 Fuel pump secondary circuit high C-07
P0230 Fuel Pump Relay Open Circuit C-07
P0300 Misfire Unidentified Cylinder Detected B-21
P0301 Cylinder 1 Misfire Detected B-22
P0302 Cylinder 2 Misfire Detected B-22
P0303 Cylinder 3 Misfire Detected B-22
P0304 Cylinder 4 Misfire Detected B-22
P0325 Knock Sensor 1 Circuit no Signal C-27
P0335 Crankshaft Sensor Incorrect Signal C-06
P0335 Crankshaft Sensor Open Circuit C-06
P0340 Camshaft Position Sensor Circuit No Signal C-13
P0340 Camshaft Sensor Incorrect Signal C-13
P0351 Ignition Coil 1 High Input B-23
P0351 Ignition Coil 1 Incorrect Signal B-23
P0352 Ignition Coil 2 High Input B-23
P0352 Ignition Coil 2 Incorrect Signal B-23
P0353 Ignition Coil 3 High Input B-23
P0353 Ignition Coil 3 Incorrect Signal B-23
P0354 Ignition Coil 4 High Input B-23
P0354 Ignition Coil 4 Incorrect Signal B-23
P0420 Catalyst Efficiency Above Threshold C-31
P0443 Evaporative emission control system purge control valve circuit shorted C-28
P0443 Evaporative emission control system purge control valve circuit open C-28
P0460 Fuel Level Sensor Circuit High Input C-14
P0460 Fuel Level Sensor Circuit Low Input C-14
P0460 Purge flow sensor circuit malfunction C-14
P0500 Vehicle speed sensor malfunction B-10
P0530 A/C Refrigerant Pressure Sensor Circuit High Input Air Conditioning System B-05
P0530 A/C Refrigerant Pressure Sensor Circuit Open Air Conditioning System B-05
P0560 System Voltage High Input C-04
P0560 System Voltage Low Input C-04
P0565 Cruise Control SET and RESUME active C-17
P0566 Cruise Control Off Signal Circuit no or Incorrect Signal C-17
P0567 Cruise Control Resume Signal High Input C-17
P0568 Cruise Control Set Signal Circuit High Input C-17
P0571 Brake Switch Circuit Low Input C-15
P0602 Powertrain Control Module Not Programmed C-02
P0602 Security Code Not Programmed C-02
P0602 Vehicle Identification Number Not Programmed C-02
P0602 Variant-Coding Not Programmed C-02
P0606 Control Unit Re-Initialisation C-02
P0650 Malfunction Indicator (MI) Control Circuit High C-36
P0650 Malfunction Indicator (MI) Control Circuit Open C-36
P0700 EOBD Error stored by Transmission Control (TC) Modul B-06
P0700 MIL request from Transmission Control (TC) Modul B-06
P0704 Clutch Switch Input Circuit High Input C-16
P1110 Variable Intake Manifold Signal High C-33
P1110 Variable Intake Manifold Signal Low C-33
P1110 Variable Intake Manifold Open Circuit C-33
P1120 Accelerator Pedal Position Sensor 1 High Input C-08
P1120 Accelerator Pedal Position Sensor 1 Low Input C-08
P1120 Accelerator Pedal Position Sensor 1-2 Correlation C-08
P1122 Accelerator Pedal Position Sensor 2 High Input C-08
P1122 Accelerator Pedal Position Sensor 2 Low Input C-08
P1130 O2 Sensor 1 Signal Out of Range C-30
P1130 O2 Sensor 1 Signal no Activity detected C-30
P1130 O2 Sensor 1 Signal Switching Time Error C-30
P1170 System too rich (Bank 1) C-30
P1170 System too lean (Bank 1) C-30
P1230 Main Relay Circuit Voltage High C-03
P1230 Main Relay Open Circuit C-03
P1326 Knock Control Maximum Spark Limit Cylinder 1 C-27
P1327 Knock Control Maximum Spark Limit Cylinder 2 C-27
P1328 Knock Control Maximum Spark Limit Cylinder 3 C-27
P1329 Knock Control Maximum Spark Limit Cylinder 4 C-27
P1372 Crankshaft Sensor Segment Error C-06
P1372 Crankshaft Sensor Adaption Error C-06
P1481 Fan Relay 1 Circuit High C-34
P1481 Fan Relay 1 Signal Low / Open Circuit C-34
P1482 Fan Relay 2 Circuit High C-34
P1482 Fan Relay 2 Signal Low / Open Circuit C-34
P1500 Electronic Throttle Control Motor Failure C-09
P1520 Powerstage Currentless C-02
P1525 Limp Home Position Error C-09
P1526 Throttle Position Adaption Error C-09
P1526 Throttle Position no Adaption C-09
P1526 Limp Home Adaption Error C-09
P1526 Lower Limit Adaption Error C-09
P1530 A/C Relay Voltage High Air Conditioning System B-10
P1530 A/C Relay Circuit Open Air Conditioning System B-10
P1540 Air Conditioning Pressure Invalid Signal Air Conditioning System B-10
P1540 Air Conditioning Pressure Signal High Input Air Conditioning System B-05
P1540 Air Conditioning Pressure Signal Low Input Air Conditioning System B-10
P1540 Air Conditioning Pressure Open Circuit Air Conditioning System B-05
P1550 Electronic Throttle Control Reduced Power C-09
P1550 Electronic Throttle Control Forced Idle C-09
P1550 Electronic Throttle Control Power Management C-09
P1550 Electronic Throttle Control Engine Stop C-09
P1551 Engine Torque Always Higher Than Expected C-02
P1555 Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load C-09
P1600 Reprogram or Replace Electronic Control Unit (ECU) C-02
P1606 Replace Electronic Control Unit (ECU) C-02
P1610 Security Code Not Programmed Immobiliser B-07
P1611 Wrong Security Code Entered Immobiliser C-02
P1612 Immobiliser No Or Wrong Signal Immobiliser C-05
P1613 Immobiliser No Or Wrong Signal Immobiliser C-05
P1614 Wrong Security Code received Immobiliser C-06
P1615 Wrong Vehicle ID from Body Control Module C-40
P1616 Wrong Vehicle ID from Instrument Control Module C-40
P1650 Service Vehicle Soon Light Voltage High C-37
P1650 Service Vehicle Soon Light Voltage Low C-37
P1700 SVS request via CAN B-06
U2100 CAN-BUS Malfunction C-05
U2101 CAN-BUS Maximum Configuration List not Programmed C-05
U2104 CAN-BUS reset counter overrun C-05
U2106 CAN-BUS no Communication with TCM B-05
U2108 CAN-BUS no Communication with ABS/TC B-08
