Kloppen deze waardes
Cobus
Beste forumleden.
Zojuist mijn Zafira uitgelezen maar heb geen idee of deze waardes kloppen.
Iemand een idee of alles klopt.
M.v.g. Cobus
Date and time>,21/04/2014. 14:4107
Workshop information:
Cobus
Selected model>,1999,Zafira,Engine,X 18 XE1
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
systemSupplierSpecific: 2430030000000300
VIN: W0L0TGF75Y2031153
vehicleManufacturerECUHardwareNumber 90582539
systemSupplierECUHardwareNumber: SIE 0108102000
systemSupplierECUSoftwareNumber: 6586035209
systemSupplierECUSoftwareVersionNumber: 0900
exhaustRegulationOrTypeApprovalNumber: S98005
systemNameOrEngineType: X18XE1
RepairShopCodeOrTesterSerialNumber: S001000509
ProgrammingDate: 20021113
Identifier: 0804
CalibrationDate: 710sE010
CalibrationEquipmentSoftwareNumber: k491e01a
ECUInstallationDate: 6586035102
Measuring blocks information:
Battery Voltage,13.2 V
Fuel Pump Relay,Active 0V
Throttle Control Sensor Signal,4.1 V
TPS Signal (Throttle Position Sensor),4.4 V
Throttle Position PWM Servo Signal,9 %
Simulated Idle Position Switch,Active
Simulated Part Position Switch,Inactive
Simulated Full Load Switch,Inactive
Coolant Temperature,92 °C
Coolant Temperature,1.5 V
Intake Air Temperature,1.2 V
Intake Air Temperature,43 °C
Mass Air Flow Sensor,0.8 V
Mass Air Flow Sensor,10.4 kg/h
Park/Neutral Switch,P - N 0V
Transmission Coding,Manual Transmission
A/C Information Switch (Air Conditioning),Inactive 0V
A/C Pressure PWM Duty Factor,1 %
Cyl.1 Knock Retard,0 °CA
Cyl.2 Knock Retard,0 °CA
Cyl.3 Knock Retard,0 °CA
Cyl.4 Knock Retard,0 °CA
EGR Pulse Ratio (Exhaust Gas Recirculation),0 %
EGR Feedback (Exhaust Gas Recirculation),1.4 V
Fuel Tank Ventilation Valve,0 %
O2 Sensor Loop,Closed
O2 Sensor,4.785 mV
O2 Integrator,133 Steps
O2-Loop BLM Idle (Block Learn Map),128 Steps
O2-Loop BLM Partial Load (Block Learn Map),129 Steps
Engine Speed,811 RPM
Desired Engine Idle Speed,820 RPM
IAC Integrator (Idle Air Control),-2 Steps
IAC Adaptation Slope (Idle Air Control),-2 Steps
Intake Manifold Valve,Inactive
A/C Request (Air Conditioning),Inactive 12V
Vehicle Speed,0 km/h
Telltale (Check Light),Off 12V
Spark Angle before TDC (Top Dead Centre),9 °CA
Injection Pulse,2.9 ms
Immobiliser Function Programmed,Yes
Security Wait Time,Inactive
Idle Air Control,20 Steps
Low Fan,Inactive 12V
High Fan,Inactive 12V
