Van Navi 600 Navi 900 maken
Heb op een engels forum gelezen dat het mogelijk zou zijn m.b.v. software een Navi 600 naar een Navi 900 te upgraden.
Hier de link : http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094" onclick="window.open(this.href);return false;
Je moet wel eerst regristeren
Dit is de tekst :
What the link did was lead you to two files
Unzip these files to the root of a Flash memory stick formated to fat32 : https://www.dropbox.com/s/wvnhsq4kazvwx" onclick="window.open(this.href);return false; ... 0to900.zip
Unzip this ISO file and write it to a CDR : https://www.dropbox.com/s/na797lj1alkew" onclick="window.open(this.href);return false; ... us_fix.rar
i) Go out to the car and switch on the navi system, remove any CD from the drive,
ii) remove the SD card,
iii) insert memory stick into USB port.
iv) Follow the on screen instructions - it will fail at about 80%, this is expected. (Mine failed at 14%)
V)Removed USB stick, insert CD, and switch unit off and on. This kicks you into the boot loader where it then proceeds to flash a load of stuff from the CD. Takes about 8 minutes. (Mine said insert suitable media, I rewrote the ISO file to a new CD at a slower speed, and it worked)
It justs sit there loading all the files from the CD for ages, you can follow progress onscreen.
vi) Reinsert memory stick, it will work this time.
Vii) Give system a chance to reboot a few times and it will wake up to be a Navi 900.
It works on mine and many others above, but its up to you!
Zie ook : http://cruze-forum.de/viewtopic.php?f=14&t=3699" onclick="window.open(this.href);return false;
Heeft dit al iemand gedaan ???
