gierend/slepend geluid z19dth
Uitbouwen bak kost je al een paar honderd sowieso...reviseren...tja... nog eens 700 ofzo? Wilde gok hoor.. Vraag eens prijs op bij revisiebedrijf van versnellingsbakken.
Mensen van andere forum met zelfde M32 probleem (er staan er ook tussen die nog wel ok zijn, maar ik vind het schrikbarend).
Rabbid 57 Astra VXR - Failed on 40k new box is 20k old now
I_AM_THE_STIG 06 30k miles and jerking in 1st 3rd and 5th with wine noise at over 50-60mph
DanEds- 08 astra VXR with 32k on clock - Bit notchy but no noise.
sam vxr 08 25k astra vxr gearbox fine also add it is mapped
JohnnyBhoy84 06 astra vxr. Failed on 40k. Got it reconditioned and failed after 5k
HSVXR 06 124,000KM 2nd gearbox , now 1st 2nd 3rd gears feel loose going in gears,but no noise!!
Red Ice VXR 08 16K miles no issues
fatboyateallthepies 55 plate zaffy vxr failed on 40k .. new one has done 27k since
Amraam 08 VXR 25'000 miles - Entire gearbox replaced
vxr maniac 06 stage 3 zaffy 37k and so far no problems touch wood i also have the lsd fitted
david vxr 59 reg, 1st gearbox failed at 13k miles. Started whining in 5th and 6th. Been stage 2 for 6 months prior to whining. Has an LSD
Moosh, 55 plate vxr with 89k on it, tuned since 40k no problems
Vxr todd 58 22k waiting on my new box. Constant noise but louder in 5th n 6th
MattW 30k standard, had the gear box oil changed 14 months ago for peace of mind, no issues with it.
novus 08 car 33k whining in all gears louder in 5/6 standard tune till 31000 miles / 220bhp/245 ft lb 31000 miles to 33500 miles
Addvxr 33k alittle notchy but other then that fine fitted with an LSD and updated bearings. EDS S3 but was on a DS map for 20k
rob1981 58 plate, 31k on the clock, 15k at stage 3. No issues.
crysb 57 plate. Stage 1 from new til 4k, Stage 2 to 14k Stage 3 ATB/bearings to present 17.5k. No problems.
stephentalman 56 arden, , over 70k in all and no problems with gearbox.
stephentalman 08 burg no problems
stephentalman 60 plate arctic no problems
kiethbag 07 plate 45K on clock no problems
vxrrob 06 plate. failed at 26k and was mapped from 18k
l66get vxr 08 burg LSD & STAGE 3- bearings collapsed @ 27k
essex kol o6 astra vxr 83,000 miles no problems
Rich_vx 07 Astra, 36k gearbox had to be reconditioned. 1st, 2nd, 5th and 6th failed. I had only done 3k at this time. 'I' haven't tuned it at all.
whytie-vxr 07 plate astra with 42k, gearbox still going strong
nellynell 58 reg 25k miles so far so good
napa1985 72k not one single problem been good has gold been running around 350lbft for over 3 years
AstraVXR_Red 41k no problems as of yet
Vauxtillidie 06 , 40k miles standard apart from remus, noise on idle until clutch is pressed, no whines/selects all gears, cant be sure if its gearbox related
insanejim69 55 plate, 47K - still original gearbox and no noises or probs at all
joshvxr failed at 22k miles
S500TTV 11 plate arctic edition 3200 miles, in having a gearbox replaced just now, kept jumping out of 2nd gear
VXRStiggy 57 plate - 49k no problems
YTVXR 07 sold at 39k miles no issues whatsoever or slippage running eds maps over 2 years
danielhoworth Failed at 10k, repaired under warrenty (after putting up a massive fuss)
beefycol 2006. 46k. Stage 2. Had gear box wine in 3rd and 4th for 15k.
tin545 08 nurburgring Standard car,well looked after 16k on the clock.Dreaded whine going in on thursday to vxl.
alan77k 08 plate burg. Gearbox changed under warranty last month after getting a whine in 1st & 2nd gear. Failed around 30000 miles
billyjo45 58 plate lightning silver 19k - no probs at all smooth as silk
lee parkhill Had whining in first gear and lightly in second 36k miles on the process of being repaired Gearbox due into dealership tomorrow 11/05/11
crazyjames astra vxr with lsd fitted covered 26000 miles no issues at all
headcharge911 06 - 35,000 - mapped with a few other mods - no problems
nurburg608 No problems on mine at 50,000kms
dick01 My box went at 33k, 2008
ginga ninja 2006 Mapped stage 2 @ 20,000kms gearbox shot and flywheel too @ 51,000kms (metric system )
tecky 57 plate, coming up to 30k miles and no problems (touch wood). Standard except for full Remus which has been on since new.
greyhamule 06 reg 41k stage 2 since 31k no problems
tasvel astra opc nurb done 105.000km stage 3 from 82.000 no probs.. quafe lsd and new bearings at 83k too
plr06 58 plate new gearbox at 20k due to whinning
burbiovxr 07 astra vxr - 44k, whining from 2nd gear.
ashwrx 58 astra vxr burg,mine is fine,done 32k
the hood 40 ish track days 17,000 miles and still going strong
silver fox 06 Astra VXR failed at 35000
Hmm, dat zijn er genoeg.
Gaat hij wel langer mee als hij gereviseerd is of blijft het een zwakke versnellingsbak? Misschien ook maar meteen het vliegwiel vervangen als de versnellingsbak eraf is aangezien dat ook al een zwak punt is :swear
Is er nog wel even mee te rijden of kan hij mij op ieder moment in de steek laten?
De lagering is te zwak uitgevoerd, en die gaan kapot, Ze kunnen er betere inzetten. Klopt dat vliegwiel is ook niet een van de sterkste.
Ik zou gewoon es naar de dealer gaan en hun even laten luisteren zodat je t zeker weet. We speculeren nu, maar hoe je t omschrijft kan t bijna niet anders.
Ik had even een prijsopvraag gedaan bij http://www.versnellingsbak-revisie.com" onclick="window.open(this.href);return false;
Ze vragen er 1200 euro voor inclusief in en uitbouwen. Het lijkt me een vrij aardige prijs, heeft iemand ervaringen met dit bedrijfje? (het lijkt gewoon een klein bedrijfje aan huis te zijn).
Ik was ze ook tegengekomen op ebay. Helaas heb ik niemand in mijn omgeving die dit soort dingen kan vervangen in mijn auto :thumbdown .
Het zou bij mij dus neerkomen op een versnellingsbak revisie incl in en uitbouw etc. Daarom was ik benieuwd of de bovenstaande prijs realistisch is of niet.
Wat ik overigens ook apart vind is dat soms het geluid erg aanwezig is en soms helemaal niet :wtf
ik heb een soort gelijkend kwaaltje gehad met mijn astra g die had op dat moment 78000 km gelopen en geloof mij rij er niet mee door bak kan vast slaan
aangezien die van mij een 1.6 se is met een f13 ben ik ook gaan zoeken maar maar mijn bak was niet meer te redden ik had aan de binnenkant van mijn bak een gat ter grote van een euro zitten lager kompleet weg geslagen dus op zoek geweest naar andere bak en die loopt goed nu
in jouw geval zou ik uit kijken met jouw bak aan gezien jij een dubbel massa vliegwiel hebt en die zijn heel prijzig
dus...... ik zou er wel vaart achter zetten en het is zeker weten de bak zonder twijvel
succes verder
